J juanblanco1911 Member Jan 23, 2013 #1 Jan 23, 2013 #1 hs50 vintage tecumseh Old 5hp tecumseh has good compression $100 shipped Last edited: Jan 24, 2013
Truckasaurus44 Member Jan 23, 2013 #2 Jan 23, 2013 #2 You may want to check the HP on that engine. If its a 143-665082 then I believe its a HS50, 5hp. I have the same engine.
joshua. c. Well-Known Member Jan 23, 2013 #3 Jan 23, 2013 #3 if you look in the second picture the modle number is listed. and it dose match the one u just posted. so i gess its an hs50.
