5hp piston project?
Thepaetsguy
I am waiting for a $18 65.5mm piston with a 13mm wrist pin from a china shipper. Claims piston height is 48.5mm 65.5mm bore 13mm pin VERY CLOSE to a stock 5hp piston.
The stock 5hp wrist pin reads 12.4 I have very carefully opened it up to 12.8 and intend to polish it the final 2mm to fit the intended China pistons 13mm wrist pin.
NOW MY LAST HURDLE the .5 overbore am I nuts to think I can hone .5-.8mm out of a 65mm aluminum bore?? I have a block that is a .5 over candidate. I don’t fear going at a junk bore with an AGGRESIVE hone. FC2968DB-F015-4EDA-A259-9545C2D3ACCB.png 6C0FC9F2-454C-4498-B03B-0E246F98811E.jpeg F57EF57B-F827-4597-84A7-180886850D5D.jpeg 9ADDFF02-2C8A-4363-B381-32C807A77450.jpeg
You could probably hone it to that. Obviously wont be as true as if it were bored. But why do this. There is aftermarket high compression pistons available for the 5hp Briggs. That was/ is a popular kart engine
Thepaetsguy
I have a few standard bores for longer rods. I don’t think anyone is going to have a boxed up cheap standard bore wiseco just laying around from the 90’s.
I really just noticed this piston was close for a stock billet/non billet 3.875 rod and wondered if i could pakastani machine it to fit.
Thepaetsguy
This is going way left field but I had a 327 with a 283 crank and stock pistons that I think set them .250 down in the holes and they had been running it like that. I wondered if having that HUGE chamber would be good for the smog pump.
You need to pump a whole lot of air to compensate for 5:1 compression.
I still have a 327 with a 283 crank with 6 inch rods. Had to use 350 pistons.
(Home made 302 Chevy)
Stock rods would have put them 1/8 inch in the holes, not 1/4.;)
Thepaetsguy
Are you stroking a 4 horse or destroking a 5 horse?
What is your goal here?
I never checked the height from wrist pin to piston top. I am working with a worn 5hp block. Until MiniMichael mention that I was assuming it was the same.
I have a 2 Horstman 4.5 length rods for wiseco pistons. I can mill one out to see if it pushes the piston back up to the top of the bore.
I guess the end goal was to get a very worn 5hp back running with blatant disregard for machine work. I have boxes and boxes of 5hp parts so a junk block and an $18 piston is no loss.
