I went out and bought a set of pin drills today with the intention of getting my stock db30 engine running again.
Here's where I need the help.I had drilled the stock carb jet too big without knowing what the original size was.I figured out that i can fill the hole with solder and drill out a new hole,but I can't find any info on the stock jet size.
Anyone know what size pin drill bit I should use?
