Why can't I run alcohol on a standard gas carb?
Miniquadman New Member Jul 28, 2012 #1 Jul 28, 2012 #1 Why can't I run alcohol on a standard gas carb?
minibikin' Sho-nuff Jul 28, 2012 #3 Jul 28, 2012 #3 As said you need to increase jetting. Depending on the carb or fuel pump you may need different gaskets as well.
creia Jul 28, 2012 #4 Jul 28, 2012 #4 In addition, generally the TIMING would need to be changed as well.hmy: Michael
