semi recently discovered that Manco made "mini" versions of their 3 and 4 wheelers, finally saw a pic of one and was on the lookout from there. Now boys this one is rough but mostly all there and decent enough to work with. not sure if this is gonna happen but i hope to make this one a low budgeted "respectable" for trikefest in june IF i can even make it. has a new 212/tav 30 on it but i plan to drop my drag bikes 228/tav30/juggernaut on it for now but eventually i want to build a nice 5 hp flatty briggs with e start/charge coils and as much reliable hp as i can with that combo. These are slightly bigger then a atc70, so i'm 5'11" and 230 lbs, just a light seat down on it and ready to ride and it wasn't too cramped, so perfect size as i thought. I want to terrorize some of those honda guys at the drags with it if possible lol
I am gonna try to use plastic epoxy and window screen to reinforce and repair the cracked and missin areas. thats after I strip the layers of thick brushed on paint off. I will then get it in ready to paint stage and leave it as i may try to splash a fiberglass mold off this (also plan to do front fender for this one and some parts for the fullsize quester like hatch lid and gas tank cover) to make replacement bodies. I found 2-3 without bodies, so this be a great way to save those bikes. since its so rough, i don't feel bad about puttin a mm212 frt fork setup on it. I do plan to make the body/seat/rims look 100% stock though when finally done, but it will just have hidden horses and sportier 19x7-8 front tire on it, with the stock rear 18x9.5-8's on the back, should look like a baby 200x.
the seat will have to get done sooner then later, any suggestions for a high quality foam to give it some real cushion for as thin as it is? I thought a really dense lower layer with one of those gels of some sort on top, this sound like it might work? don't know much on that side of things and whats available anymore.
I even picked up a giant banner and got a couple hats and shirts to rep at trikefest lol
