B&S engine id help
What hp? What year is it? Is the pto side cover interchangable? i wish to shorten the cam and get a side cover with the 4 bolt hole pattern for mounting a torque converter. Thanks!
Whoops....wait a minute 100292 ....sorry I punched in 100202 ...I think yours is a 4hp, not sure if these parts interchange or not.
Yes that's a 4hp, the piston is a little smaller and the stroke is a little shorter on a 4hp Briggs but everything else is the same between the 4&5hp Briggs engines. The head on a 4hp Briggs is a higher compression head than the 5hp.
Oldschool....I just remembered that I have a 5hp Briggs engine with a bad block ( bad cylinder), I have a good side cover and a good stock cam for it though. If you need it ..It's yours for free just pay the shipping.
