Baja jackshaft mounting question
ugmold
Today I got a couple of master links so I can install the chain. Clutch to jackshaft-no problem. Jackshaft to rear sprocket doesn't seem right. The front sprocket looks angled and with engine mount bolts loose doesn't seem to want to align straight. I am wondering if does the jackshaft assembly plate butt up to the engine mount tab on the inside or the outside?
I currently have it on the outside. I looked around for other pics and they look on the outside too. Mine seems to be straight.
Still can't seem to upload images: top photos
Baja Minibike
Thanks
ugmold
Thanks Raskin,
I moved it to the other side and alighnment looks better. One factor I had was the bottom lower Chain guard mount was bent in a bit hitting the frame. I know there is an upgrade unit, but have to make do for now.
