I've got a VT-8 that I'm wiring. The bike had blinkers on it. I put in a 2 pin LED relay. I have this switch cluster, un the picture. The #2 wire is power to the blinkers. I wired the L side of the flasher to #2 and wired the B side to an on off switch that's connected to the battery. My headlight #6 and tail light power is also connected to this switch, so I can shut off all power. My problem is when I turn on the blinker it takes the tail light and headlight flash. Maybe I have the relay wired in wrong? Not sure what I'm doing wrong. Here is a pic of my great wiring diagram skills if that helps.
