Delray
I could try taking a video but since it's just me riding it could get scary and end with curse words, when Rupp is up to full speed I will get a picture of the speedometer and post. I am not sure if fixed position timing of more than stock .035" would benefit an engine that can be driven at lower engine speeds, I was running .055" advance with the aluminum cylinder HS50 and noticed is sounded rattly driving at mid range RPM under a light load, it's my understanding unleaded fuel burns faster than leaded, more timing might not help overall driving. The only way to know for sure would be to tune it on a Dyno, that would be fun if someone had one around here. The engine isolation plate was removed this afternoon and cleaned up going to try black high heat silicone rubber, if that doesn't work I have some 1" thick aluminum to replace it. The weather in Maine this weekend isn't going to be very good hoping to have the mount done by Sunday, the 19mm carb will also get some attention. A good part of the better acceleration is from going back to the larger Rupp rear sprocket, I am thrilled this bike has the potential to cruise at higher speeds, after driving it only 200 miles the last two years I am hoping to ride the wheels off it this year.
A big thanks to the guy's here that build their engines beyond stock and all those who have offered advice, I didn't know companies like DynoCams existed their parts make a difference.
Tony
