brigs 2 hp throttle hook up
Briggs 2 hp 1974 Where is the best spot to hook throttle to and what return springs are u using. Mine was hooked up 2 different ways one throttle went straight to butterfly flaps the second went some spot hard original cable went to then springs went to butterfly flap. Two motors hooked up different.
Harquebus
Got photos of your engines?
Engines that have an internal mechanically geared governor are easy IF you wish to maintain the factory governor.
Their throttle controls attach to the governor linkage under the fuel tank, for example.
