Hi all!
It's been a while since I last worked on this project, but I finally got the mini out of it's snow prison and I'm back to work :thumbsup: There's a good 8 feet of snow in some places, and I'm not kidding. The swimming pool is invisible now under all that snow! This is getting ridiculous!
Anyway...
I was unsatisfied with the axles I had build previously. The wheels wobbled a bit and the pulley was not perfectly concentric. So, I used a lawnmower rim in the rear and put a plate on it to mount the pulley. The center of this rim is 3/8 thick and is machined so I knew it was straight. I pressed a couple of brass bushings and used some 7/8 drill rod for the axle. Ridiculously overkill!
Same recipe for the front wheel and axle: brass bushings and 7/8 drill rod. So now only the wheels turn and not the whole axle. And everything spins dead straight now!
Next I will make mounts for the rear axle and relocate the brake on the jackshaft. This way the brake will need about 5 times less force to operate, so I will be able to use a regular bicycle brake lever.
Stay tuned :hammer:
