Can this work
If this is a pic of the carb that you are going to Install..then yes it will work...and the aluminum hat is what the air filter fits over.
:thumbsup:If you look in the hole on the back I believe that is your breather hole :shrug:
Ok thanks briggsraptor i thought it could maybe be that. Ok i thought it could work and ya i know the aluminium is for the air filter. Thanks
125ccCrazy
that looks to be a Raptor carb... if it was on a race engine before you got it be sure it's not drilled for alcohol or you won't be able to run gas in it if that's the plan..
I checked the cateyes ther are for gas. Im just confused because THERES NO BREATHER HOLE so idk lol. Also no choke
brazing copper is what i do for a living.b4 that i did all kinds of weldind. brazing is much easier and perfect for copper and very strong yet flexible.
125ccCrazy
it's a factory race carb (Raptor) so they never came with a breather or choke...The carb will work but may be a bit hard starting cold unless you hand choke it...as far as the breather either run it straight down, to a catch can or up with a small filter on it...it's better not to hook the breather to the carb so your not pulling oil into the cylinder..
Ya i get it now the breather is for recycling. Im here to have fun i dont need to be efficient . Thanks
