my bonanza with a jack shaft has broken two
chains so far. what i have is a front peg with a
swing arm. the engine is a 212cc predator with
a 12 tooth clutch with 41 chain driving a 12 tooth
gear on the jack shaft. on the left side of the jack shaft
is a 17 tooth gear driving a 45 tooth gear with a 41
chain. i used a square to line up both chains and lube
the chains on a regular basis and had no problems on short
rides.
on longer rides the chain between the jack shaft and
sprocket breaks after about a mile of road riding every
time. both chains were new from OldMiniBikes. the picture below
shows one end of the chain, the inner plates expand and
some of the pins look like the outer plates are moving outwards.
is it a chain tensioning issue or alignment or what?
what to do???????
phil
rides.
what to do???????
phil
