Umm..you've heard me talk about them from a six HP point of view. LOL, the 7's are actually more rare than the six or eights.
But they are basically the same engine. I have the six on my Tote Gote, and that's the one I've been bitching about there. (Carb) And while there may be a million flow jet carbs out there, try finding one without stripped emulsion tube threads, or a stripped bottom bolt.
And if you DO find it, please send it to me. I have two of those carbs and both are bitches.
For example, if you do get a bottoming tap into the emulsion tube hole, don't nick that bit of brass at the bottom, because that angled piece has to seal against the emulsion tube. And do get a new tube, because the last guy took the carb apart and bent it because he didn't remove it first, because it was corroded and stuck, and that's why those threads are dicked in the first place.
Throttle parts are not a problem, and if using on a tote gote, you don't need much of it because you'll get rid of the gov. Yes, I have an intimate relationship with this whole subject. I even have a seven with a bad crank, bad rod, and bad block. :laugh:
