I am rebuilding a rope pull Clinton Panther A400 2 1/2 hp engine for use on grandkids kart.
Need clarification: I have seen footnotes on Clinton parts lists that say their A400 kart engines were built without governors.
Is it ok then to leave off the fan govenor? Also, is it ok to replace the iron flywheel with the aluminum flywheel? If I change out
the flywheel to aluminum, so as to rev quicker, then must I also upgrade connecting rod to the heavy duty conn rod. Lastly, with the engine sans govenor parts
do you replace carburator (Tillotson) with a direct linkage?
PS need kart exhaust. What other than the E65 megahone exhaust fits the Clinton?
