Greetings..I am having issue with my gearcase cover leaking from gasket on gx200 clone..I just replaced it a few weeks ago for same issue..I checked pcv breather is clear and hose OK..should I use this sealer along with new gasket? If i use this will it be a real pain to remove it if i got to go back in? Should i make a copper one? I have heard bad things about rtv silicone stuff getting in engine..is stock aside from muffler and air filter..I did remove jackshaft as you see to gear it higher to ride on dirt road and a few pavement cruises..I don't care about low end..I read maybe bad head gasket could cause pressure to cause leak.only 10 months old...I don't know torque specs ..but seen done on ytube not using torque wrench..just snugging up good..any input appreciated.. thanks..
