Recently I have removed the entire governor of my hisun 196cc. I have also changed the carb to a VM22 slide, switched exhaust, fly wheel and torque converter. (Disclaimer I am using a tachometer to limit my RPMs to<4k before I change the stock rod). After attempting to tune my new carb with what seems to be a smooth idle I am having issues at the initial throttle engagement where it seems to struggle taking off. From that point on it seems to even out for a smooth cruise. Along with the initial throttling issue I am noticing a burning smell as if it’s plastic and white smoke coming from the muffler. Attached is a what new spark plug looks like after 20-30 minutes of idle-low end riding (maybe 3k rpm). Engine oil was changed recently when I removed the governor. Not sure if this is relevant but when I was inside the engine the two rods that sit on the cam feel thru so I simply put them back in without adjusting the valve springs. Possible points of trouble shooting would be greatly appreciated. If I left any info out please let me know for I am very new to small engines (let alone any engine) and am relying solely on YouTube and forums to not screw up entirely.
