DB 30 suspension
2SlickNick
Looking good. It looks like you might get 2-3" of travel before the seat pan hits stock frame. Do you plan on cut stock frame rear end out for more travel.
I took the easy way out and just added a springer seat. Any plans for the front too?
Do you think I need more room for travel? It's just sort of sitting there for now. I can jack it up a little bit. Maybe something for the front I saw stuff you posted before. Right now I just want to get the thing running been a long process .
2SlickNick
I think those shocks only have about 3" travel, right? So maybe what you have is good enough. I was simply giving you something to think about before you weld. Also to consider what are those shocks rated for? weight wise...
I had ones similar in the past rated 150lbs.
Also the seat looks great!
