each hub maybe machine little different? so 1 1/2 could be litte tricky
best thing to do is mic out your wheel hub that you new sprocket is going to mount to. so you can machine out the center bore to the correct size:thumbsup:
if it can be honed it will be an ultra custom fit use a smaller size blank and hone it to the size you need whatever that maybe. measuring your bore and having one machined to that size i imagine there's a price tag regardless of the fit.
