Briggs 6.5 OHV Engine
Ok so here is the deal. Runs, but not great when the choke is on. As soon as i take the choke off, it dies. BUT if I hold the throttle full with choke off, it runs awesome, but will die as soon as I let off the throttle.
So....I was told by someone here that the carb was leaking air and to replace the seals.
Today I installed a new bowl seal, that plastic block that is between the carb and engine, the two seals associated with it. I also replace the needle type plunger that connects to the float in the bowl. The float also is good, sealed, no fluid leaked inside.
So I goto start it, starts 1st pull, I let it warm up with the choke on @ 75% for a few minutes, as soon as I start to take the choke off, the engine dies.
I start to think maybe its not getting enough fuel? I drain the tank out, clean the inside, make sure there is good flow, cleaned the fuel lines out, no filter so no need to worry. Put it back on....same deal.....dies with choke is off.
What is the problem? I am really stumped? Help! lol
