Hey guys,
Since finding out about Windber I want to get things ready.
I had previously modified a Doodlebug into my Doodle Devil. I added side mount fuel tank, Devil's tail sissy bar, and some tabs for leaner sidecar mount.
It was awesome with just a C.C, but needed more torque and smoother transition when pulling a sidecar with passenger. ( sidecar will be complete soon).
I was going to purchase a TAV unit for $100, but figured I would work with what I have.
I did swipe and modify my TC set up from my go kart.
I need plenty of torque and power to pull sidecar with another passenger and the 20 series with 7" driven should do the trick.
I had to ditch fender mount, but will figure that out later.
TC mount is rectangle tube 1/4" thick that measures 12" x 5" x 3" I welded a bearing tube on angled steel and then onto rectangle tube.
I did have to cut out a notch to allow chain clearance for this set up.
I will try to have finished tonight or tomorrow and then hopefully test run....
Here is a quick vid of sidecar a few days ago with C.C.
https://www.youtube.com/watch?v=F3KwWJyr7K4
