WOW, what a huge difference...
I swapped out my 60t rear sprocket for the original 75t that came on the Motovox,
then turned the idle up 1/2 turn (dif between a low rumble and running engine ready to rev),
then tuned the idle with the little idle adjustment screw/jet (the one that doesn't do much),
it's a ruxing carb.
Holy Hallelujah; there is no lug at all, smooooth take-offs, easy to ride,
pop the clutch fast starts, wheelie's are breazy, I did my first smokin burn-out, AND I bump started it too....
Ok, so I didn't jump on it till after it started, but it was a good push bump start. Hahaha!!!
I couldn't be happier! If you have a few things that need changing to get this to work for you,
change 'em. After I calm down I'm gonna make another vid....:innocent:thank you
and here it is...
http://www.youtube.com/watch?v=i9ktC7IKjrU&feature=player_embedded
