I just tested mine, on my jackshafted DB30. Its a nice clutch, well made, accurate dimentions and nice finish, they chose a good shop to mill the parts.
It works, and YES it hooks up extremely tight. With 1/8" slack in the lever it starts to grab at about half way off the grip, but the majority of lockup happens at the last half inch of travel. I did a few pinned wide open holeshots on dry pavment, a burnout and tried to ride normally too, at which point I noticed I need to gear down more, as this clutch has more teeth than the old max torque and it just plain hooks up....I feel it can handle some serious HP,
alot more than my built flathead had for it....Neck right, just bump start it....easy and safe, otherwise get that locking lever guys.
I built my chain without a master link, the one supplied by RLV was so close, installed either way, i decided not to use it, just didnt want to scuff up the clutch. A standar master link might have a better chance at not hitting.
I placed my clutch lever over top of the brake, and figured out I could pull in clutch then brake with the outer three fingers....yes wierd, but I
had to ride it.:laugh: afterwards the clutch was extremely hot, smoking from the assembly grease on it, and I could smell the fiber material. I let it cool, checked it over real good rode it again, and its worked perfect. As the lining wears it looses slack in the cable....so set it up such that the adjuster on the perch is screwed out a bit.
short video:
http://s818.photobucket.com/user/5X8Rider/media/MB165sDB30_zps74d20acc.mp4.html
levers:
