Instead of removing the factory air box, installing the adapter, and then adding the filter with the Stage 1 kit, could I simply leave the air box intact, remove the top cover, and factory filter, then install the Stage 1 filter with a suitable clamp to the air tube that the factory filter was connected to? The larger Stage 1 filter would remain uncovered of course and offer better airflow. Rather than extending out beyond the frame, the Stage 1 filter would be located in the same position as the original factory filter. If this is practical (and I do have an appropriate rubber tube which fits the air flow tube and the Stage 1 kit filter) would the performance be similar to the carburetor adapter clamp on filter mod? Would I also need a new jet ( which I have)?... Thanx again
