Nothing much worse than being out in the woods or desert, and getting a flat tire.
Here's one I read about somewhere, and was wondering if anyone had tried it.
This is for a new/good tire.
Before setting the bead, you take a garden hose and feed in as much of it as you possibly can, coiling it up inside the tire.
Then set the bead, and fill to desired pressure.
It's supposed to give you a halfway decent run flat tire.
I also got to thinking...
What if a guy drilled another valve stem hole in the opposite side of the tire rim, giving a valve stem hole on each side of the tire.
Then insert two inner tubes, side by side, and fill each one equally.
What are the odds that a tire puncher is going to get both tubes?
One goes flat, pull the nail, thorn or whatever, and fill up the other tube up with a small bicycle tire pump.
I've tried the green slime, but I'm not totally sold.
And it's a mess when changing tires.
