I have a 1971 Speedway Scorpion front fork rebuild in progress. The hard part is done as you can see... Someone had pumped grease into both sides!!! What a freaking mess!!!
PLEASE HELP!!!
I need plastic retainer rings that fit to rubber. As you can see, mine are broke. One could be salvageable but the other is not. WHERE TO FIND THESE PLASTIC RINGS??? Also I would like some springs, because as you can see, one of mine came out in rusty pieces. I see there is a set of springs on "ePay" and will most likely bid for them because I need them, but those plastic rings??? Where to get them???
What would you use to clean rust out of the tubes and forks? I need some sort of drill attachment with a wire brush on a shaft or something? That or get them cleaned out by a shop before finishing? Would a person refinishing them clean up the insides? I want to have my fork tubes powder coated black to match my frame and I want everything else refinished nice and shiny. What should something like this cost and are there any suggestions where to go. I live in Omaha Nebraska, if that makes a difference.
Lastly, what kind of hydraulic fluid is being used on these forks? Are there any certain recommendations? I sure the hell will not be pumping grease into it like someone else has done prior to my ownership!!!
PLEASE HELP!!!
