I'm pretty much done with the fork at work so I started grinding on the frame to take it in too. now things are a little clearer, I thought this was an early frame for the last couple years its been floating around between friends, but now I finally started working on it I grinded all that crap off and heres what was underneath, I wanted to keep the bent bar cause it looks like the older model and would make for a cool seat mounting point, but the geometry is off. So I'm thinking about a 1 inch straight bar across the top. What do you guys think?
As for the forks I kept the lower sprung section on cause I thought it might be cool to run a bicycle wheel later or something, I reinforced it up back and welded a piece of perforated steel on the front for a different looking number plate, pics on request.
I'm gonna keep the rear honda 50 wheel for now cause it already has a chain and foot brake rigged up. plus I wanna see what kind of top speed I can get with a tall tire.
