He guys so with m other post i was finnaly able to get the correct parts for my go kart but i have another problem i broke my bearings es i bought some new ones but i would like to know is there a proper wa to put bearings on m axle or do i just oil m axle ith engine oil and slide it on this is also the same for m sprocket do i just slide the sprocket on with some oil and heat it up with a torch or is there a better w to do it because my other sprockets bent or broke the tooth b hitting it with a hammer which seemed like the onl wa it would work but it bent or broke it so is there a proper way to put m go kart sprocket nd bearings on my axle for miniam damage
