I have a question that needs the power equipment specialist to answer. It took 6 gallons of diesel fuel to mow my lawn so, how much ah capacity would I need to do that same mowing on a single charge?
You gott'a be putting me on, Mariah. LOL
If your supposedly mowing a lawn with something that would take 6 gals of diesel to do it, that's not a lawn,, but a frigg'n field. lol
One 5ah ''Li'' battery in a 40 volt ''brushless'' push mower'' ,, will generally run around 30 - 40 minutes, depending if it's self propelled or not.
That also depends on how high & dense the stuff you are mowing is also,, to determine how much load you are putting on the motor.
Generally a 30 - 40min run time with that 40v, should knock out 1/4 - 1/2 acre
So a 10 ah battery would probably cover 1 acre, & run at least 1 hr.
2 acres would be 20 ah, & 4 acres would be 40 ah ,, ect. ect.,, with that 40 volt ''push'' mower. LMFAO !!
Added,,
There is a new EGO 42'' Z turn that we offer for ''a lot'' of coin.
It is 56v, & comes with 4 - 56v 10ah Li packs, that are wired in parallel,, ''like how my Kart is''.
With the 4 included packs totaling 40ah,, It will generally knock out up to 2 acres on a single charge.
It also has 2 more slots for 2 more packs,, which would give a total ah capacity of 60,, & would probably knock out an extra 1/2 acre or so ..
The power of that Z turn is the equivalent of a 22hp gas engine.
Total price of that Z turn with 2 extra packs, & with 7% tax ect. out the door,, is ''only'' just around 10K.
