I have this keihin carb on my gx160 and when i turn it on it seems like its already hitting the gas and then when i do hit the gas it accelerates more i am not sure how to idle it and advice would be great right now
make sure the slide is in the carb right, if it's 180 out it won't set all the way down where it should be in idle position..If that checks ok then check for air leaks...
