Does anyone have some good correct throttel set ups for the rupps like the tt-500 or the digger I have 6 h-50 and all the throttels are different :drinkup:
If you have any that look like this, you can make it minibike correct. By replacing the stop screw with a cable ferrule or whatever there called. If not then you need to buy the parts. Brandt has them for around $60.00 I think. If you can find them at a local shop the parts are about $30.00. The shrouds have threaded inserts but if you don't have the correct shroud you can use nylon lock nuts.
Common cable type:
thanks randy that helps alot and yea 1 look like that with all the snow I decided to rebuild a moter for the new digger the honda 3 wheeler got stuck can you see a honda in the pict
