I recently purchased a CL Baja Heat with Hemi Predator. The carb throttle lever moves easily enough, but the original Baja twist throttle is heavy & long(to twist full open). Is this a cable lube issue or something else?
The nut on the linkage is not snugged tight. The original speed control lever is easy to move.
I would like to lighten it for a more 'motorcycle like' feel. Plenty of power, I just added a gopowersports TAV-2 clone & this heavy mini will pull the front wheel with my 220lbs on it. I even considered converting to a lever throttle, but that may be too sensitive.
Thanks for all the suggestions!
New jets & E-tube on the way from OBMparts to go with my ARC exhaust & air filter. So far all stock til all the aftermarket parts are here.
