PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
HI EVERYONE I GOT ANOTHER PROBLEM MY CLUTCH IS SHOT!!!!
All i have is another clutch that is 10t chain drive, well the only other gears i have for my jackshaft would be 12t in 12t out, 60t final axle.
well that didnt works so well gearing must be way to high the clutch always works its way off the crankshaft, i tried everything even a bolt inside the clutch with a tight fight custom washer, it still pulls off, dont help that the engine is an extremely short shaft like 1 1/2 in, but still what gear should i use so that i can get some torque and speed both, plan on using 1 of the 12t on the jackshaft out but what size should i use for the jackshaft in?????
i dont see why i f the jackshaft has the same sprocket on both sides my final gear ration would be 6:1 with my current setup right, how come the clutch will smoke then when it does want to work,,,,,
im lost isnt 1;6 the area i want to be in im LOST!!!!
Thanks any help would be appreciated again the engine is a briggs 5hp flathead tiller engine, they all are tiller engines i have 5 total
PLEASE HELP!!!!
PLEASE HELP!!!!
