Not sure if I understand correctly but sounds like it runs but dies when not being revved up?
I would quickly pull the float bowl off and check for water or dirt, get a paper cup and catch the fuel coming out when unscrewing the bowl so you can examine it.. If that does not work you may have to go deeper into the carb. Also check for sufficient fuel flow from filters petcocks etc. :thumbsup:
