I need a little help finding a replacement bearing for my jackshaft. Just the standard 3/4 by 1 3/8's bearings.
I want a bearing made in the USA and the best possible quality bearing. As some of you know I am using a 40 series torque converter with a 420cc Predator. My plan is to run the JS through a tube welded to the bike. It will be bored to the proper ID and deep enough for a double bearing behind the driven with a single bearing on the other side.
It seems all I can find is the run of the mill "Made in China" bearing. I wouldn't hesitate to run these behind a 212 but the 420 has enough torque to destroy them in short order as I have been told by a fellow member. I don't want to have to replace the bearings at all if I can help it. Normal maintenance replacement is what I am looking for. I know they wont last forever but the longer the better.
As always thanks for the help guys, :thumbsup:
Doug
Doug
