Help me ID this H60...
I have an old Tecumseh that I believe is from the early 60's. I believe it is an H60 but not sure what the model is to know what parts to get etc. I cannot find any ID on it anywhere. I found 2 numbers cast into the block. They are:
19-0-70
IAI-0-240
This motor has a 3/4" shaft that is straight on one end and tapered on the other. If you need any other part numbers there are a few on the points set and condensor I can post that might help.
It's a H50, H60, or H70. Without the shroud for #s, the only way I know would be check the bore and stroke, unless the port sizes were different. Either way, they're good engines. They even made a H40 like that back then, but very few are ever seen. They may not have made as many of those.
