I will be watching this to see what you come up with. I am the ding dong that bought the ones from eBay! Please post pics when you get this sorted out!
Sucka born every minute :laugh: If I had known the bolt pattern I would have bid on them too though :wink:
If the wheels dont flare down too small (might want to measure that I just noticed the flare in on simple toms pics) you could sink a bendix brake and spocket on there from a 64-67 Rupp continental series, they had a huge center opening, all the others you would need to hog the center of drum out to clear the hub.
4 of the ten thousand holes drilled into the Azusa drum sprockets line up with the that bolt circle dimemsion, and the other 2 appear to be unobstructed on the drum so they could be drilled, the also have a 2" center opening. They are the smaller 4 1/2" brake so you may be able to sink one of those down into the wheel and then use the flat plate steel brake assy they sell as well.
gonna be important to be able to really sink that sprocket in for Chazp the Sensation is a really skinny bike at the back and I dont think there is much room to play with!!!
