when you are browsing you albums in photobucket, mouse over (do not click) the thumbnail of the photo(s) you want to post in here. You should then see another box expand down below the thumbnails when you mouse over. The very last white field box that pops up will have some code in there with these brackets around the code [blah blah blah]. Click on that field, it should say 'copied'. If it doesn't say copied, then manually copy that code. Then switch back to the forum and paste that code in here. Make sure and separate multiple codes by hitting the retun key so that they are not on the same line. When you submit your post, it will show up as a picture. Give it a shot and let us know.
