I have two motors I need some information on.
first - I think the motor is an R. It is on a 68 K2, put a different stater so it has the correct number of wires to plug into the correct wire harness. Long story short, trying to put what I think is the correct carburetor on for that year. I have the carb, but the hook up for the throttle is different. Can I change just part of this set up, or do I have to get an entire new cable?
Second motor - on an 87 50r. making a lot of noise, thought it was a sloppy timing chain, tightened that, no help. adjusted the clutch, no help. motor seems to run good. noise goes away when i hold down the gear shifter. Any ideas?
Any help greatly appreciated. Thanks!
