Newbie govenor question.
i had the gc motor on a gokart great little motor . if you attach the end of the cable to the governor arm at the top with a hose small clamp and tie rap the cable it self to something solid the throttle will work fine
Hi,I'm new to this site and minibikes in general,even though I've been a mechanic for 20 years. My question is probably stupid,but I've recently
replaced a 10 Hp Tecumseh with a real Honda 5.5. The govenor arm,when
moved from all the way closed,at the adjustment screw,will just bog the engine down and probably stall it if held open.The lever above the fuel
shut-off is the only throttle lever that the engine seems to have.I thought
that would be the choke,but I must be mistaken?Can someone help me figure
out where the choke is,if it even has one,or is it built into the govenor arm
linkage?I'm just at the point where I need to mount my throttle cable to the
linkage,but am seriously confused when you guys are mounting it to the
govenor arm,that would just stall my engine?I'm lost,please help.Thanks Alot.
Dave W.
