R racer32 New Member Feb 24, 2009 #1 Feb 24, 2009 #1 Does my shaft need to be? And NO, not THAT shaft! :thefinger:
G GTO Feb 24, 2009 #3 Feb 24, 2009 #3 You can get a max torque long keyed clutch and adapter plug if you are stuck with a small shaft. If you are talking about the other shaft,, I think there's an adapter for that to!
5 5 Horse Fan New Member Feb 26, 2009 #4 Feb 26, 2009 #4 Some clutches work with short shafts. Some need longer shafts to bolt on to, like the racing clutches. Bottom line is: If your making lots of power, you need a long shaft or you could shear the keyway.:thumbdown: I have seen it happen.:doah:
