Another novice question for those with on-engine vertical seam tanks. Engine originally had horizontal-seam, plastic tank with outlet nipple in the center/bottom of tank. No problem with fuel line radius out of the tank into the shroud. I now have reinforced rubber fuel line installed and made the switch to the vertical-seam tank w/nipple inboard. I can't make the bend at all.
To make matters worse, I wanted to use an inline filter. On one hand, that would allow extra hose making the connection to the tank easier. On the other, way too much hose dangling below the tank (and below the carb float bowl). I believe I saw that these tanks have an integral filter within the outlet? That would help but what about bend? Maybe a photo of a working connection would sink into my old brain...
