But the good news about those half breed early HS40 snowblower motors is that you can make them work.
I took the fly wheel and set it on the lathe and turned off the electric start gear ring. After you do that, you essentially have a 32517 fly wheel. It’s actually a little lighter weight than a 32517 fly wheel.
Also on that shroud, with some cutting and some gentle welding you can make it look exactly like a standard Minibike shroud.
Bottom line, don’t avoid those engines. They’re pretty awesome
