Same old story picked R2 I can pull on the starter until well I can't pull anymore.
It pops, It fires but it won't start. I installed an original rebuilt tecumseh carb I've given it a shots of quick start and it tries but still nothing but blisters and a soaking wet shirt.
1.5 Main
1 low idle
turned up idle set screw
Seems to have lots of compression as well.
I even changed to carb to and older tecumseh adjustable carb.
The carb that was on it was`a Lauson Power Products it is adjustable but has no bowl like the tecumseh just diaphram on the bottom.
Lot of popping firing and sputering but no start
There is fuel in the bowl that much I do know
I might add that this doesn't have the slanted intake and the carb is tilted. I dont know this will affect the ability to run or not.
1.5 Main
1 low idle
