My sons CAT 400TS stopped running and I know it’s the carb that needs rebuilt or replaced. The engine is an HS50 snow blower engine that has performed great for him up until now. The #’s on the shroud are HS50-67175C SER 9156B.
I have a few questions on fixing the issue. If I were to rebuild the carb, what is a good rebuild kit to use? If I were to replace it with a new carb, what would be a good replacement carb? Lastly, I have a H35 with a good carb, would that be compatible to use on the HS50? The H35 is newer than the HS50 and the #’s are H35 45621U (A) 3266B.
thank you for any assistance the OldMiniBikes community can provide. Of all the mini bikes I done in the last 10+ years, this will be the first carb that I’ve had to fix. I’m in uncharted territory, please excuse my ignorance.
