Some times they're like that... :laugh: Try screwing the idle fuel out more and the idle up a little bit and see if it helps it start cold...
Look and see if your carb has the tube on the bowl vent.. If so you can just plug a primer bulb onto those carbs and hit the primer a couple times.. If you look at the top of the carb, same side as the idle mixture screw, on the back side kinda kitty corner the idle fuel screw, there will be like a little brass tube sticking out at a 45 degree angle.. It's only like 3/8 inch long.... I've noticed these newer carbs that HAS that tube, DO start a little harder for some reason.. :glare: I think the hole through the center of the emulsion tube is bigger, so theres more cavity, needing more vacuum to pull fuel up the tube...
But thats just a guess.. :laugh:
Also, if it starts a little hard no matter what, the carb may be too big for the motor..
