Here's a question to those who have done it. HS50, isky cam, same as yours, arc rod, cleaned and polished ports, stock rebuilt carb with better air cleaner, header, and basically every other tid-bit I found you guys doing. QUESTION: advance the timing ? and to what degree? With or without key? and how, it's a points fired motor...( no g'vnor)
