pilot washer. It prevents the clutch from coming loose due to the washer bending. It's expensive until you see what one of these clutches can do when it comes off under power.
Richard....... where does that pilot washer go? The only washer I have on the setup is a stepped washer that fits between the engine and clutch that centers the clutch shroud.
There wasn't anybody local that carried ball bearings, all the bearing places do not carry them. I ended up with 4 7/8 balls from a place that had 4 stuck in a drawer and wasn't on there inventory, lucky me or it would have been $20 and 5 day wait on the internet.
I do have a problem though. I have no idea what the original balls weighed and the ones in there are allowing the clutch to pull at idle, I have to have both brakes on to hold it. Maybe my balls are too heavy? Have you ever run a clutch with two balls missing? I was gonna try that. Gawd knows if I would ever be able to get the right weight balls. As it was I was lucky to get balls at all locally
Could be my springs are old and weak.... are there replacements?
Thanks
Joe
