I am in need of some ideas for a custom mini bike that I want to build. I am going to make a frame so looking for ideas on shapes or possibly of other bikes already built that I can copy from.
The bike is going to be used on trails, fields and in the woods.
Engine:
I am putting a 9 HP Robins-Subaru engine in it. Since I am building the frame, the size of the motor will not matter fitting in the frame.
Suspension:
I want to do a spring suspension on the front and back. I can get some springs off a midget car but may look for other springs if someone has another idea. I am not sure how much the guy wants for the springs. I would like to see some pictures or ideas for suspension on the front and back.
Tires:
I was thinking about putting 14 inch tires, since I am running a centrifugal clutch. I am open to idea on the tires. I have not seen the Doodle Bug in person but noticed on their website that I can get a tire and rim for 30.00. I do not think that I can go with a bigger tire because I'm using a centrifugal clutch and not a torque converter.
Centrifugal Clutch:
I was going to use the Comet 1" centrifugal clutch Comet Clutch - 1" Bore - OUT OF STOCK, BMI Karts and Supplies - Home I have seen the clutch on ebay a lot so know that it is still available.
Sprocket:
I was going to run a 60 tooth sprocket on the back wheel.
Drivetrain:
I know that a torque converter would be the best route but the price is too much.
Any other ideas on the drivetrain would be appreciated. I thought about a jackshaft but then thought that I would loose some low end power and more parts for something to go wrong. I did find a Jack Shaft setup for the doodle bug the other day. It looked like it help. I think it was called PMI, a bolt on accessory. I might could try something like that. I do need some ideas about the positive and negatives of having a jackshaft setup.
Price:
I want to do this cheaply but with a good design and something that will be solid and take a beating.
Justin
Engine:
Suspension:
Tires:
Centrifugal Clutch:
Sprocket:
Drivetrain:
Price:
Justin
