Sounds like something may have gotten bent. If you can't adjust the idle speed with the idle set screw/stop then check all the linkages for binding, etc. and see if something is out of place or disconnected.
Is the governor still hooked up and functioning? It may be forcing it to run too high at idle.
Check your return springs/governor springs.
Check the throttle cable adjustment.
Try disconnecting the throttle cable and see if it'll idle.
Then disconnect all the other linkages and see if you can make it idle by manually holding it against the idle stop/set screw. (don't over rev the engine)
Photos or a brief video would help eliminate the potential problem.
